Torsion springs: End view and 3D
Mode
Tool
Tool set
Torsion Spring - End
Torsion Spring - 3D
Machine Components
Multiple torsion spring tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a torsion spring - end view:
Click the tool and mode.
Parameter
Description
Wire Diameter
Enter the wire diameter
Outside Diameter
Specify the outside diameter of the coiled section of the torsion spring
Number of Active Coils
(3D only)
Specify the number of active coils in the coiled section of the 3D torsion spring
End # 1/2
Select to enter the dimensions for End #1 and/or End #2
Length
For each end, specify the length between the coil center and the bend
Deflection
Enter the deflection angle for each end
End Style
Select a style for each end (specify a clockwise (CW) or counterclockwise (CCW) direction)
Bend Radius
For each end, specify the radius value of the bend (does not apply to Plain End Styles)
Bend Length
For each end, specify the length between the bend and the wire end (does not apply to Plain or Full Loop End Styles)
Spiral
Select either a Left Hand or Right Hand spiral direction
